Hole Denn
The underdog I used is that butyl sticky stuff, the 1 Lex quoted states its foam, not sure if same thing or which would be better but even 10ml rolled down hard might be to high for other things on top to fit easily.
I used underdog behind and under rear seat/back wall and boot, seat was a hard fit with the underdog 3mm. I havent finished the floor yet and might use the 1 Lex showed as a 10ml foam underlay/sound substitute under carpet instead of the underdog.
