The exhaust starts are as follows, Hydrocarbons 0.93g/kg, Nitrosoxide 1.93g/kg and CarbonMonoxide 9.1g/kg.
Mine failed big time, it was misfire alot due to the big injectors and a couple of computer settings
I read 9.03 HC, .43 NOx and 69.1 CO, NOx was down because to much fuel causing the other two to skyrocket.
I got the test booked again for April 10 so i got to change the injectors back to standard, change to a hotter thermostat and change the heat reange of the sparkplugs then got it tuned again. and see how i go then.
VP_luke, i suggest putting a standard computer and injectors and emission gear/ manifolds, sensors to get it engineered, because i don't think you will need an emissions test if you do that, then once it's engineered put the aftermarket on with bigger injectors....
Things i took out were boost controller, microtech dash because you could adjust fuel mixtures with it. and i had to plumb back the BOV and plumb the wastegate.
engineers you will need the brakes upgraded to the VL turbo, VN V8 brakes to be satisfactory, i went for the VT twin piston setup. or off ebay theres the big brakes conversion.
Make sure all the factory emissions gear is there like PCV, Charcoal cansiter etc...
thats all i can think of right now, you can call up your local engineer or the one you are going to use and ask anything you are unsure about, i did a couple of times just to make sure, it should be free for general questions over the phone i'd think.
If i think of anymore i'll get them up.
