VN Intermitant stalling/won't start
bido1
VN Ex-cop car
After a short drive the other day my VN wouldn't start after 10mins I went back and it started 1st pot. Then 5 mins down the road i kicked the throttle it lit up then spluttered and konked out! another short rest and it sprang back to life. Two days have passed and driving it is a tender task. I've sat and got the car hot (1/4 temp the hottest it gets) and stopped the motor and restarted it with no probs most of the time so i dont think heat is a contributing factor. Don't know where to start my bro says fuels pump how can u tell? all help would be greatly appreciated:>)
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
Hmm Could be a number of things....I had a very similar problem.....Was the fuel pump in end....
OK so what happend to me was i could drive for bout 10-15 then i would start to loose throttle (wouldnt be able to use more than 1cm of throttle) if u put ur foot down too far it would stall even @100km...
Went to mech, he said deffiatly a Crank angle sensor prob, so changed it, got 15min drive did it again, went bak he said it may be a dodgy crank angle sensor so he changed it again for free, did it again so i told him to check the fuel pump as when it playd up the pump was really loud n wouldnt stay at the same tone.....
He did a pressure test n it was fine cept that it would loose pressure after car was turned off, so i told him to change it anyway, picked up car n didnt have another problem....
So if ur fuel pump is gettin really loud n not stayin at same tone id say its ur pump but if u can throw a bucket of water on the crank angle sensor and it starts straight away then that would be the problem....
Hope this can help in any way....
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
Ohh when it doesntstart does it stink when u try to turn it ova, coz mine had a weird smell when pump wasnt pumpin properly
sircruisealotVS
South Brisbane
VZ LS1 Calais
sounds like it could be a fuel supply problem, change the fuel filter first (only a couple of bucks) and see how that goes. check all the other usual suspects too, like a battery and alternator test (probably isnt this, but doesnt hurt to check) you can get them done at auto parts store for free (like autobarn, supercheap,etc.)
bido1
VN Ex-cop car
Cheers my bro is down in 30 mins to do the work we have a few spares to change over but will start with the pump let you know and thx again. TOP FORUM SITE!!
bido1
VN Ex-cop car
nah no smells at all or smoke froms the car atleast!!
Taking her for a cruise now and hopefully the new pump has fixed the issue!
