volts jumping all over the place 10 to 16v help needed please
bogan_vk
australia
commodore
ok my volts are all over the place my headlights go dim then like there on high beam but theyre not this has happened after i did some arc welding on the underside of my vk im thinking its some sort of regulator problem but im not sure where the regulator is on a carby vk or if its even got one for that matter or could it be another problem? im not real good with electrics.any ideas or has anybody had this problem and fixed it, thanks.
muttley383
Donating Member
VR 383
Yes, sounds like your regulator and possibly the alternator is stuffed.
If the alternators in the VK's are the same as the VR-VS's then the regulator is in the alternator. It is easy to replace and costs approx $40.00, 2 screws and you dont even need to remove the alternator. It may be wise to check the diodes in the alternator in case your welding has fried them and giving excessive AC ripple output.
bogan_vk
australia
commodore
thanks so the regulator is the black box on the back of the alternator with the brushes attached to it ?
muttley383
Donating Member
VR 383
yes that is right.
bogan_vk
australia
commodore
yep the earth strap was disconnected at the battery terminal but my mate connected the arc welder earth cable direct to the battery lead going to the alternator.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Sorry if you really like your mate, but he is a dick......
acarmody
Donati..Whoa Green
VX Berlina
Your mate used the positive lead on the cars wiring as the earth for welding??? I'm surprised you didn't do more damage.
Next time use the chassis itself.
bogan_vk
australia
commodore
as the old saying goes "if you want something done properly do it yourself" ill be sticking to that.
