ok, i did notice some oil around the bottom of the radiator, i just flushed the coolant n changed the oil in the motor and the oil was fine, how do i check tranny oil and tranny cooler????
there is a dipstick near the oil one, on the drivers side closer to the firewall, and you cant check the tranny cooler as its inside the radiator, if the tranny oils milky to, DONT DRIVE IT, youl **** ur tranny
Hey mate was wondering if you have fiqure four your problem as my vp s2 is doing the same it won’t start unless I hold the throttle wide open to let air in or something and then when it does it will run real lumpy and usually stall and backfire out the air box, and like you said once it starts you can smell fuel
