Vp on 20" with +40 off set , any suggestions -new arms or or bolt on spacers??
Calais666
victoria
VL CALAIS / VP CALAIS
Any suggestions ? And also has anyone had any issues with the spats if spacers were used ?
Calais666
victoria
:rockon:
Anyone have their vp's on 20'' wheels ?
ducker85
Narnia
09 VE clubbie R8
have you even tried them on the car? how wide?
VP senators come on 17x8 +30P offset wheels which is the large factory VP wheel. If you have 20x8.5 with 245/30R20 tyres they should be close n might only need a 3 or 5mm spacer. any longer then 5mm (so 8mm-12mm with need longer studs) 100's of people have run 20s on VPs mate just take Felony for example (google this white Calais)
here's another example
nqrith
44
warrnambool
vp calais
i run ve 18s and had to change the rear arms over to vr one as they rubbed on the inside. all good now
Calais666
victoria
Awesome reply , and pic thankyou .. these wheels came off a wh statesman and run 225/35/20 , they fit on his perfect with no mods, i just read through felony's thread... very nice ! im assuming from what i have read they will fit the front .I bought them of a mate and our vp is on the other side of town atm.. but ill give them a go next weekend .. i might see if i can get some new arms like it suggests above .. hmmmm :/
Calais666
victoria
Thankyou for the reply , was this an expensive process to do ?
Calais666
victoria
Just found this you posted some time ago :D
Yes if there 30P they will fit an IRS VP with no mods.
getting sick of this questions can we make a sticky?????
VP & VQ IRS cars NEED 30p offsets
VR-VZ IRS cars run 48p offsets
hence the VP different (wheels track is almost 40mm narrower)
bloody 20x8.5 30P offset wheels fit I've seen it done hundreds of time already!!!
here's proof or Google Felony a white VP Calai
ducker85
Narnia
09 VE clubbie R8
The WH has different front struts, Holden seemed to change the design from VR upwards. WH would have 17x8 +48P offsets factory so the only way to tell is try them (without checking offsets). 225/35 tyres suit VR n up but hit the struts off VP n older hence I suggest 245/30 tyres, which is what Felony ran.
The only reason why VP and VQ's have rear issue's is because they were the first Holden's with IRS and the diff's were too narrow n had different offsets compared to older Commodores like VB-VL's so when the new model the VR came out they fixed the problem. the VR parts from a wrecker would be cheap. I have all the gear pictured here (you dont need the axles tho)
nqrith
44
warrnambool
vp calais
all i used was the arms and new discs all the rest i swaped from my old arms cost me $60 for the arms and i also put a camber kit in while i was at it.
92vpss
33
Tasmania
Vp ss
Hey calais666 here's a photo of my vp ss. It's got 245/30/20 with no spacers and it doesn't rub. They only just fit
