Vp trim color code?
Coaldust666
22
New Zealand
VG
Trying to find out the colour code for the trim on my vp wagon, I'm told it's the sandalwood colour but I haven't got a number to get a custom can made up etc.
Also trying to do the same with a vg but I need to take some photos for the thread.
NORTI
Radelaide
Wildtrak
For the VP it would be either
62i classic beige
63i Smokey beige
MasterOfReality
Miners go deeper
44
All over
2019 LC Sahara TTDV8, 1991 VP Calais V8
I just went through this as I have restored a second hand centre console with a colour change to Steel Blue 23i. To get it colour matched you will need to send a trim piece to the paint shop. Even then, if there is sun fade then the match wont be exact once you spray it.
Coaldust666
22
New Zealand
VG
Unless I take in a piece and go off the plastic side that's been against steel the whole time..
Looking like that'll be the way to go
MasterOfReality
Miners go deeper
44
All over
Thats a possibility. I think even the texture will make it appear different too. I had the door grab handle and the radio surround colour matched. The grey was a bit off but the blue was pretty much spot on.
Prep is the key to getting a good quality finish. I did 2 coats primer and 6 coats colour.
This was supposed to be colour matched to the radio surround, its not close and even the way the sun hits it makes it look different:
The Steel Blue however was a really close match:
Finished console:
