vr 5 litre running rough when hot nearly stalls when takeing off
Critterkent
34
Vr ute 5 litre
alternators charging I haven't noticed the lights dim and its missing when idling at the lights go to take off it shutters really bad then once moving it has no power and struggles to get to 80
gtrboyy
vt ss & lc gtr
Checked leads/cap/rotor etc.
Sounds like dropped more than one cylinder if really bad off idle but I'd expect it be electrical.
Standard check is bridge pins 5 & 6 for fault codes.
Critterkent
34
Vr ute 5 litre
thanks mate I will recheck them just to make sure I missed something it runs fine in the mornings drive for an hour no problems but on the way home when there is traffic it starts running rough and loose power.
VR38
VB SL/E
Temp sensor in spec?
VR38
VB SL/E
Alternator belt tight?
Critterkent
34
Vr ute 5 litre
so i have checked leads alternator belt dizzy swapped ignition module everything seems to be fine and still having the same problem I have found that if I don't get stuck in traffic I have no problems its only happening when I get stuck in traffic I'm a bit lost on this one
VR38
VB SL/E
Old radiator?
My VS used to cook in 40deg heat and traffic with A/C on
Mew OEM copper type radiator fixed it.
Critterkent
34
Vr ute 5 litre
The radiator isn't to bad I cleaned it out probly 6 months ago gave the motor a flush and new coolant . I am going to film what its doing and post it up . I will also put up a photo of what the temp is sitting on when it happens
Critterkent
34
Vr ute 5 litre
That's where the temp sits when its playing up
