VR Problem
Kovacic_VR95
South East
VZ CALAIS
How can i tell if a car is running off 5cyclinders?
and how do i fix this?
cheers
JA2Z
East Gippsland, Vic
www.studiomarban.com
VT 5L, WH LS1 Stato (Daily), TDCi Focus, Probe V6
Hi,
I would suggest starting with the ignition component of the combustion.
1.) one at a time, while the engine is idling take off a spark lead from your coil pack. if it idles more roughly it would suggest that it is not that cylinder, replace the lead and check that the idle returns to how it was prior to removing the lead.
2.) repeat this for each lead, if removing one or more of the leads does nothing to effect the engine's idle it would suggest that there is an issue with those leads/spark plugs of the coil for that cylinder.
3.) if none of the leads makes any difference it suggests that your plugs, coils & leads are ok, you may be looking at a fuel or compression issue, i.e. an injector may be blocked or require cleaning or you may have fried a piston ring. if this is the case a professional may be required.
hope that helps
Just a note: don't use your bare hands to remove the leads, it will shock you. try carefully using a set of good pliers to gentle pull off the lead.
Kovacic_VR95
South East
VZ CALAIS
Cheers mate ill check it out and get back to you asap on that one!
Yea its been idling rough, even when at 1000rpm and the exhaust makes this putt putt putt noise not a straight noise
VR38
VB SL/E
Don't take a spark lead off while the motor is running, you may get a shock and damage the module, to test if a cylinder is not running disconnect one injector plug at a time and listen if the revs drop and idle diminishes.
This way you also keep un burned fuel out of the exhaust/cat.
Kovacic_VR95
South East
VZ CALAIS
ok im confused now haha isnt that the same thing haha....
what else could i do to stop the car idling rough?
what do i do for a tune up? cus i cbf taking it to a mechanic!!
cheers
VR38
VB SL/E
Just disconnect one injector at a time while the motor is running.
If the revs change that cylinder is good.
Kovacic_VR95
South East
VZ CALAIS
ok so if the revs dont change then thers a problem! and all i have to do is put a new lead on that injector? so if the revs dont change its **** ok think i got it :)
Skater_jj
Ride Or Die.
Kalgoorlie
VR
1. find out which lead is causing the issue, genally noticable by the revs not dropping at all when removing the lead and and change the lead.
2. if changing the lead over doesn't fix it check the spark plug and clean it.
3. if cleaning the spark plug doesn't help replace the spark plug.
4. if changing the spark plug doesn't help then you probably burnt out a ring and should seek the aid of a mechanic or mechanically minded friend to help fix it.
Kovacic_VR95
South East
VZ CALAIS
thanks for that mate ill definatly check and do all that!
cheers
let u know how it goes
Kovacic_VR95
South East
VZ CALAIS
Ok i checked the leads and the injectors on the weekend now I did the process u told me for the injectors BUT yes one failed NO#3 when i pulled it off while engine was running it died straight on me but when i pulled all others off the engine revs just changed and the engine didnt die!
So now iv found the problem with injector NO#3 what should i do??
