Looks like going off your spark plugs 2 are wet, if they are in the right order then depending on what side each set came from its either 3 and 5 or 2 and 6, You want to grab yourself one of the spark plug testers u place on the leads to see if its not a spark problem, you say you replaced a lot of things depending on the brand some times things like DFI or coils can be faulty been new, most v6 engine pass a little oil as they wear on the bottom side more than the top. It looks like its something to do with spark to me, make sure the dfi plug pins ant bent or worn.
