vr v6 not running with a cam sensor?
CHA53R
vic
vr wagon
how bad will not running a cam sensor play with my ecu? i boaught a s2 vn motor and it does not have one and my s2 vr does.. if i tie the cable aside will it stuff with the ecu too much? or could i get a vr s1 ecu and eliminate the sensor from an ecu? cheers
CHA53R
vic
vr wagon
any one? please
hako
Donating Member
81
Toowoomba SE QLD
VS11 BT1 V6
From what I've read, if the cam position signal is missing, the ECU just uses it's default value, which I'd guess is no real problem. I'd suck it and see rather than swapping timing chain covers.
Good Luck.
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
All VR autos run cam angle sensors.
MR.HG
Donating Member
HG Brougham, VS Ute, VR SS
maybe you didnt see where the OP said - he put a vn motor in that didnt have one, he would also like to know : if by not having one, will it screw with the vr ECU.
CHA53R
vic
vr wagon
thats right lol anyone?
4wheelinls1
Carrum Downs
Ralliart
You can turn off the code in software, you'd be wise to tune it anyway as it is a different engine somewhat.
bpefi
Tech
Bundaberg
Hilux Ute - Vs Ecotech Engine
It wouldn't damage the ecu - may not run properly but
CHA53R
vic
vr wagon
how do you turn the code off?
4wheelinls1
Carrum Downs
Ralliart
In software, I use Tunercat and TunerPro RT, you could also do it in Kalmaker at twice the cost. You have to delete and reburn the memcal with the modified tune. All the sensors other than the cam are the same, the ECU will be fine. You may have to shorten the coolant sensor wiring if it is an old VN motor with the rear thermostat, and the gauge too. MAP, TPS, IAT, Coolant all the same, it might be worth using the DFI and coils off the existing VR engine as I don't have the wiring diagram here to compare them and I think the cam/crank wiring goes through the DFI to the ECU.
Joel
