Vr Windscreen Washer aim?
walkahz
Vr Wagon
Just installed a new washer pump into my vr. Problem is now that the water shoots miles too high and just lands on the roof barely hitting the screen.
Any ideas on how to aim these better?
zelby11
Banned
NOWHERE
SCOOTER
Are the water exit holes on the bonnet? They might need to also be replaced as they would be warn,try and just get a safety pin and stick it in the holes where the water comes out and move it around and see if the water hits the wind screen
Red_Vs_Ute_18"
27
qld
red vs commodore ute 3.8 1995
id go with what zelby said i just pulled mine out the other day to paint them and they only go back in one way so u wuldnt be able to adjust the angle of them at all realy. hope it helps
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
all youll do is poke the **** back in and it will want to come back out again and re-block it...carefully take the rubber hose off the back cause they break easy if you dont, then blow air in the hole to blow the crap out the back and plug the hose back on...too easy...
mischa
Donating Member
Ruse, NSW
355 VN GRP A REP
I aim them by puting a needle into the nozel and move it to where i want it to aim. So far no one has mentioned how to aim them just how to clean them?
Brett_jjj
Tamworth NSW
vs commodore
I was gonna say the same thing,you can aim them where ever you want by doing what mischa said,put a needle in the hole and move the jet around until it squirts in the right place on the windscreen..
The_Captain
VS V8 Ute
yep - that's what I do too. Sometimes a bit of "gunk" builds up and you need to ensure that you do not push it down into the hose.
walkahz
Vr Wagon
Cheers all used the pin trick and aimed them down works a charm.
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
Im sure that zelby11 mentioned that you move the pin around until the aim of the water is on the windscreen
