vs auto problems
tommy rebz
30
griffith
vs commodore s2
hi my vs v6 auto s2 does not matter whether its hot or cold it will rev out to 6k (limiter) without changing gear in both 1st and 2nd and very rarely will select 3rd or 4th. any ideas??
another problem is when taking a corner an aweful grinding/ rattling noise is emmited from the rear of the car, pretty sure its the diff.
i believe it to be separate problem, any possiblity these problems are related?
thanks.
Tom.
Jxfwsf
Aus
commodore
checked for fault codes?
LS1 James
Donates His Member
39
Andrews Farm, SA
VT II GEN3 V8 Wagz
Drained your trans fluid and checked for discolouration and metal.......?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Re the trans, try replacing the throttle position sensor - this tells the trans when it's time to change gear.
Re the rear noise...could be the rear uni shot or if IRS rear end could be cracked cradle allowing diff to move. You need to get under!
Dylan_11
newcastle
vs bt1 commodore
hey mate i went threw 2 autos because they done that. i went an easy way and put a l67 calais auto in. just shave a bit of the belhousing off on the left hand side so the exhaust will fit. best decision ive made
Jxfwsf
Aus
commodore
and that is why you don't buy them from ebay when they have the description "Was working fine when removed" like a 2nd hand engine you want to see it working atleast before handing cash over
