VS Dash Green Circuit Board Repair
Macca177
40
Goldcoast
VS Statesman V8
Heya,
Hopefully not a dumb question, but can I repair/improve the contact around the base of the globe holder? Just this one globe keeps going on and off and that circuit doesn't look the best.
Circuit pen/paint okay? (about $35 from office works etc) or is it okay to take to it with solder? Is there another product that would help the contact best - I've not played with this green boards like this before.
07GTS
Australia
VEGTS BUILT BLOWN E85
crush the contacts on the globe (lightly) so it holds a little tighter then dont do it up all the way just go to a spot that it work good in
ltdslip
SYD
VT2SS
try cleaning it up first with a pencil eraser,
if you're handy with a soldering iron, solder the copper to build up the surface
krusing
Melbourne, Bayside
I second that,
maybe clean the contact surface with some fine wet and dry sand paper,
then apply a thin film of solder [as mentioned above], and that should fix it.
Macca177
40
Goldcoast
VS Statesman V8
Perfect thanks for the replies.
ltdslip
SYD
VT2SS
careful with the sandpaper, you dont want to remove any copper, just clean the contact area
07GTS
Australia
careful with the soldier heat as u can melt the contact of the c/b easily
Macca177
40
Goldcoast
VS Statesman V8
That's why you get the wire glue from jaycar.
exactly this, no heat, cleaned with a eraser and then applied the wire glue. 24 hrs too cure so it will go back in today and check its all working fine.
