VS gets stuck at 2000rpm when sitting idiol
pugga
More Power!!!!
Baxter
05 HSV Maloo R8
when the car is sitting with the foot on the brake or even in park the car sometimes sits at about 2000rpm
need help
thanks
95 VS V6
Harvs82
42
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
need help
thanks
95 VS V6
Check your IAC (Idle Control) device on the throttle body, sounds like it is stuffed, or clogged up with a lot of crap. Try cleaning it with throttle body cleaner, and make sure that the electrical connections are clean, dry and secure.
If you start the car without the idle control connected, it idles at 2000rpm, so it sounds like it is faulty. Also check your ECU for fault codes, and see if one has been stored.
