vs hard to start poor idle
djbrooksy05
launceston
vs heappa
hi guys and girls
i have just got myself a 95 vs with a ecotec for a work bus
the car has cleaned up nice with a scrub and a buff
but im having a few problems with the motor i knew it had them when i got it but i was hoping
for a quick simple fix but not so lucky
the car at times is hard to start will just wind and wind and wont come to life
some times it will start and stall start and idle ruff and as soon as you touch the go fast pedal
it snuffs out
if it dont snuff out you have to feather the pedal a bit to get it to rev
when its like that at times i hear a slight pop sound from the air intake.
but then there is times it will start and run fine with no problems at all
i have checked the pcm to see if it had and codes logged and no such luck
have put a new fuel filter and has new plugs and leads in but it has not fixed it
i know how to spin a spanner and have a firm grasp of the delco efi system
but lack the money to be chucking random parts at it in hope of a fix.
so chuck some ideas at me of things i should be looking at and checking
i tryed to get a vid so you could hear it but it was wanting to behave
but at soon as it starts playing up i will post a vid
cheers
brooksy
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
Does it do hot or cold or both? Have you cleaned the MAF and pelum lately? Make sure the IAC passage isn't all blocked up. Get some MAf or contact cleaner for that and use carby cleaner to clean the throttlebody.
djbrooksy05
launceston
vs heappa
hot or cold dose not matter
have only had the car for 2 days so who knows when it was cleaned last will check it out when i have some daylight
Z2TT
VL Commodore
Check/Renew Coilpacks, Leads, and Plugs.
Trikky
Central Coast
VF S2 SV6 Manual
+1 for what The1 said, clean MAF and take the throttle body off and give the IAC a real good clean
