Jxfwsf
I don't think i would've worried about a coil pack just yet, usually plugs, leads and a tune is all that most problematic. Atleast you now have a spare if you ever have problems with it
Code 35, i wouldn't be to concerned about that either atm, just means the ecu is having trouble controlling the engine idle, could all be to do with the out of tune lpg system.
I wouldn't mess around with unknown 2nd hand spark plugs (unless you have a sand blaster, small file and feeler gauges to clean and regap them)
a brand new set of standard plug should be between $24-$30....
2nd hand leads are a gamble also.... I pulled a set off a wreck once, they looked newish, on gas it idled fine and moved around the yard fine, free revved fine under no load... but when I put them on my daily driver as it was due for new leads it backfired and blew parts of the plastic intake to pieces upon hard acceleration from being stopped (they ran perfectly on petrol as well)
http://www.ebay.com.au/itm/DRIVE-FO...=AU_Car_Parts_Accessories&hash=item1c2d0c8486
for less than $50, 5 year/100,000km warranty it could be a worthwhile investment (same brand i have been running for the past 20,000 km's without an issue)
alternatively there are some cheaper options on ebay
http://www.ebay.com.au/itm/IGNITION...=AU_Car_Parts_Accessories&hash=item20c97a0f70
my pick if you get them in time for the sale would be the bosch ones
http://www.ebay.com.au/itm/Holden-N...=AU_Car_Parts_Accessories&hash=item2574fdbb0c
It's great that it's now running good on petrol, like most people that work on lpg will tell you "no point trying to tune an LPG system if it's not running on petrol correctly)
Another problem is that the ignition side of things may (plugs and leads) may run perfectly fine on petrol but will not on gas, before trying to tune it replace the plugs and leads.
Back yard tuning may suffice for some but in all honesty it's much quicker and easier to take it to an LPG specialist that can shove an air fuel ration sniffer up the exhaust and tune it within minutes.
If possible, can you remove your current spark plugs and take a pic or 2 of each one clearly showing the same area as the below pic (more light in the pic would be good).
Note what cylinder they came out of and name them respectively.
Looking from the front of the engine on the passenger side from front to back is 1, 3, 5
on the drivers side is, 2, 4, 6.
