VS irs rear sway bar link bush replacement
HoldenHoon
33
Australia
VS Berlina V8
Hi everyone. I’ve got a vs commodore fitted with irs and I was wondering on how to pull off the rear sway bar links as the top of the sway bar link looks like it’s pushed into the sway bar and I’m having a hard time pulling it off. Any clue on how to go about this? Thanks.
BlackVXGTS
Melbourne, SE
The attached document from the Holden VS Service CD should provide what you are after:
  • VR-VS Stabiliser Bar & Mountings.pdf
HoldenHoon
33
Australia
VS Berlina V8
Thanks mate. I’ve just got to see what tool they used to pull them off. Those factory rear sway bar links don’t look that solid and have heaps of flex in them. My bushes still say GM on them and they are rock solid I can’t even swing the sway bar link it’s just stuck in a certain position.
losh1971
North Tas
VE Series I SS Ute
@vs-lover will likely know what you need.
