[QLD] Vs V6 Auto Transmission with shift kit
commomad
Sunny Coast
vr berlina
4L60E VS V6 Auto Transmission. Shift Kit
Item: 4L60E Automatic Trans. with shift kit fitted. suit VS v6
Description: The box was removed from a 96 VS executive sedan, some parts replaced, fitted with Stage 1 shift kit, serviced and then tested on Autotransmission dyno. Firm shift 1st to 2nd and 2nd to 3rd All worked was performed by Qualified Transmission machanic.
Price: $480
Contact: 0414490609
Pictures: Post pics this week.
Gus The Snail
Born to be dizlegzic
ipswich - on the right side of the tracks
VS ute S2 1996
When you say rebuilt.. was there new servos , bands and all the rest replaced? , and will it fit in where a 6HDD resides?
commomad
Sunny Coast
vr berlina
Description
Yeah basically man. took the box to my mates workshop, pulled the whole thing apart, checked all the clutch packs and replaced some of them. new band and smoothed up the drum that the band grips on. The servo and the pump were both pressure tested, not replaced and a shift kit was fitted. put it all back together and put it on there gearbox dyno that spins it up just like a car would.
So really it is not a completely rebuilt box with new servo and solinoids, but like i said my mate is a auto box builder and knows his **** so, it will shift hard and last a far while.
Aslong as your ute is a floor shift not a column. this box will fit it.
commomad
Sunny Coast
vr berlina
The difference is the selector shaft that comes out the side of the gear box, the colum shift has a longer shaft out the side of the box than the floor shift. The shafts can be swap, so your selector shaft would swap over with the shorter shaft on the floor shift model. Is the box still in the car?
digger747
Wollongong
VR Commodore
damn only if u were in nsw!! i know a couple of people that live in QLD so ill have a think
