Harvs82
- Dec 29, 2005
- 1,134
- 24
- 38
- Age
- 41
- Location
- Glen Waverley VIC
- MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
Over the past couple of years I've replaced the DFI module, and more recently all 3 coil packs with genuine DELPHI units, which worked fine up until last week. Now have have a really bad miss, to the point that the car isn't driveable at all. Replaced all the spark plugs and ignition leads today, and the problem persists. Have tested the resistance on the leads and coil packs, all ok.
Turned my attention to the fuel injectors, and after disconnecting each one at idle, I found that disconnecting injectors for cylinders 1 and 4 made no difference to the idle. Wiring seems to be ok as we tested with a test lamp, so it looks like the injectors are kaput.
Where to from here? What do you guys recommend? Engine is mechanically sound apart from the leaking inlet manifold gasket, and has 195,000 original km... as do the injectors.
Am I up for a small fortune, what do you recommend doing etc...
