Vs Wagon high idle/sticky throttle
96wags99
24
5 Speed VS Wagon
Hi, I am having a bit of an issue with my wagon.
Few days back while driving to work I had a random check engine light come on(car still drove fine) same thing on the way home.
Next day it was idling between 1500-2000 continuously. Even when in gear(T5 Manual) you can feel the car pulling like it would have a sticky throttle, push clutch in and revs would be 1500-2000rpm.
Turned it on and off a few times and it ended up not idling at all, it would end up stalling at lights ect.
Noticed it had a manifold oil leak so I changed manifold gaskets over the weekend, along with a brand new IACV and 3 different TPS.
Got the car scanned today and it came up with 3 codes
32 - Mass airflow out of range
54- System voltage unstable
57 - Injector voltage minor fault.
So I've tried two different MAF sensors, both pulled apart and thoroughly cleaned.
Also checked for vacuum leaks from manifold and vacuum lines, still with no avail.
Hoping someone is able to point me in the right direction for some other things to try.
Thanks in advance
Have a solid week ahead legends!
Having A Break
Somewhere
Goggomobile
Did you clear the codes and if so, did they all come back.
Before I got to the part where you replaced the IAC I was thinking IAC lol.
Lots of people having trouble with aftermaket IAC's, I believe Delphi is the most reliable.
Did you swap out the correct TPS, as early pre Eco's had opposite direction.
There were probably too many items exchanged at the same time.
Change/then evaluate.
Could still be a vacuum leak.
  • Like
Reactions: Lex
96wags99
24
5 Speed VS Wagon
Yeah codes were cleared, and engine light came back on basically straight away. May have to try a delphi IAC.
The tps wasnt brand new, was just a couple of other ecos I believe one was a vs and one was a vt. May have to grab a brand new tps and give that a crack.
All parts were changed one at a time too and tested before removing/fitting another part.
Having a vacuum leak somewhere still is definitely still a possibility, hard to tell with the engine reving so high.
Thanks for the quick reply, much appreciated!
Having A Break
Somewhere
Goggomobile
....Thanks for the quick reply, much appreciated!...
Love to help...
To try and ascertain a possible leak, use a length of flexible hose held up to your ear while scanning the other end around the engine.
The noise will come up as a pronounced hisssss.
You could also spray fluid around all the manifold to head junctions etc, as a gasket could be failing.
I advise against buying more parts until you have satisfied yourself there are no vacuum leaks.
Having A Break
Somewhere
Goggomobile
I have gone over this and think that all those codes may stem from the Code 54.
Try and clear codes again, verify they are clear, then re-start engine and switch off as soon as you see the CEL.
Read codes to see if all 3 appear at once.
If so, the problem may well be the 54, with either a weak battery or poor connections, a malfunctioning Voltage Regulator in the altenator, or a regulation circuit in the actual PCM.
  • Like
Reactions: Lex
Immortality
Staff member
Sth Auck, NZ
Posts fixed.
BlackVXGTS
Melbourne, SE
Check out the attachments from the Holden VS Service Manual. They may help you solve your problem.
Also, make sure your throttle cable is not too tight. Needs to have 10-15mm of play, refer to diagram below:
  • DTC 32 V6 PCM MAF Out of Range.pdf
  • DTC 54 V6 PCM System Voltage Unstable.pdf
  • DTC 57 V6 PCM Injector Voltage Monitor Fault.pdf
96wags99
24
5 Speed VS Wagon
Thank you very much for you're help guys, it is much appreciated!
Issue is still ongoing, haven't really had a chance to look at it this week but I will have another go with the tips you guys have given over the weekend. Fingers are crossed I can get it sorted!
Once again, thank you very much for the pointers! Good to know there is still some awesome help out there! Lol. Will update on the weekend when I have another look.
Thanks again.
  • Like
Reactions: Lex
