HonestJake
- Sep 2, 2014
- 1
- 0
- 0
- Location
- Perth, WA
- VT sedan 3.7 V6 (May 1999)
Hi everyone, it's my first time posting to the Commodore forum.
The other day my car wouldn't start after a dozen attempts. Each time, the engine cranked/started but immediately cut out. It seemed like no fuel was reaching the engine. (It's done this intermittently in the past when the engine is already warm, but normally starts on the third or fourth attempt.)
This is a '99 VT sedan with a 3.7 V6 engine and relatively low mileage (180,000km). It's been very reliable in the past.
I called out the RAC. The mechanic somehow got the engine to start, then removed one of the fuses to do a multimeter reading. I'm not sure which fuse he removed but it made the engine cut out. He found that the fuel pump was sending 8.5 amps to the fuse when it should only be between 4 or 5 amps (apologies I can't be more specific on which fuse it was or the terminology). As such, he deduced that the fuel pump was 'on its way out' and recommended I replace it.
However, since then the car has gone back to its old reliable self and starts on the first attempt every time... at least for now.
Having read through similar threads on this forum I'm now dubious if the fuel pump is the real issue. I don't want to spend megabucks on swapping it out, given it's only an intermittent problem and this might not even fix it. Having said that, I no longer 100% trust the car to start so I need to resolve it somehow!
This isn't a massive problem but I would appreciate any advice from people who've had similar issues. Cheers!
