VT Commodore Wagon Rear Electric Window Regulators
YellowSticker
WA
VT Commodore
I ordered rear regulators for my VT wagon but I've since come to understand that the quarter window is different to the sedan? Rear Electric regulators advertised as fitting VT SEDAN WAGON etc. will not fit a wagon.
Getting a lot of parts advertised as fitting everything only to tear the car apart and find out its completely wrong.
Anyway, off ebay the only available rear regulators are obviously for VT sedans which have mounting bolts 380mm apart. My window regulator bolt hole centers in the door of my wagon are 360mm apart.
Can I drill a hole out 20mm below existing hole and it will work do you reckon? Are the rear windows the same size?
Anyone actually got rear electric windows in their wagon? Or know if any part is available that doesn't require modding?
May have to get from a wrecked wagon but the cost for 1 regulators is the price of 2 new ones off ebay.
Posting this as there are threads on the subject of VT wagon rear regulators being the same as VT sedan rear regulators where people are saying "yes it fits, relax" and that is not the case. They might work with some modification, but they are NOT the correct part.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
My vt wagon is an exe. (no power windows). I installed power windows. Person l bought power window setup said it was all out a Calais.
I just drilled the rivets out bolted in the regulators. If l remember correctly the regulators were all marked for which door they fitted.
I just noticed your pics. That doesn't look like a vt rear regulator to me? Is it aftermarket?
Maybe l'll have time tomorrow & take a pic of the setup?
Have you fitted the front ones yet?
Heavy VT
NorthQueensland
Vt V6
This is the one I'm using in my vt sedan rear door. It's out of a vy sedan.
The original vt one had a gal cover on the motor. It also has 5 mounting rivets.
Hope this helps.
  • Like
Reactions: Lex
YellowSticker
WA
VT Commodore
Retard detected
Just realised I was looking at probably the wrong rivet. Circled is 380mm distance.
I already returned the regulators , too. **** my life
Lex, they are aftermarket replacement ones off ebay. Front ones went in fine. Got nice door trims today which have the electric switches built in to replace the manual window door trims.
I don't really want to shell out for the door looms just to use rear door switches. I just want control from the main switch in center console. Can anyone confirm if the rear door switch can be bypassed? Or even have a diagram of the pins and what they go to?
Happy to make a plug for rear window switch, but without knowing which pin is which on it, I don't know if it's worth the effort?
UPDATE - ordered 2 window switches for rear doors with plug and loom attached. I will post photos or the plug and wiring when it comes.
  • Like
Reactions: Lex
