I've got a vt v6 gearbox will it fit into a vx
F Frog1731 New Member Joined Jun 25, 2015 Messages 1 Reaction score 0 Points 0 Location Belmont Members Ride Perth Jun 25, 2015 #1 I've got a vt v6 gearbox will it fit into a vx
dirty hands Active Member Joined Nov 25, 2013 Messages 1,445 Reaction score 11 Points 38 Location ipswich qld Members Ride magna Jun 25, 2015 #2 6 cyl to 6 cyl I would say so . seems all the automatics were the same identification and specs for both models is it ok...... to assume the the manual gearbox will be the same bolt on what does the repair manual say ? Last edited: Jun 25, 2015
EYY Well-Known Member Joined Mar 6, 2011 Messages 5,754 Reaction score 2,036 Points 113 Location Vic Members Ride VS Statesman Jun 25, 2015 #3 Plugs are different afaik
E edals Well-Known Member Joined Sep 30, 2008 Messages 1,907 Reaction score 60 Points 48 Location - Members Ride - Jun 25, 2015 #4 check this post, it should work as long as the connector is 13 pin and check the build numbers - http://forums.justcommodores.com.au...lp-will-vt-auto-transmission-fit-into-vy.html
V VT clown Member Joined Mar 31, 2021 Messages 49 Reaction score 2 Points 8 Age 39 Location Darwin Members Ride VT Jun 24, 2021 #5 Will a vs auto fit the vx or only VT vx fit the vs auto is 7hdd
