VT loses power after 2 mins running, won't rev over 1500 rpm
Rigga
Gold Coast
VT Wagon
Thankyou devilly & derbatua;
"thing's i have noticed, where the blue hose connect's to the throttle body you will find a small hose underneath it.
this needs a tinny ring clamp on it to test if this is the problem put a zippy tie on it."
HOSE WAS NOT SEALED, ZIPPED IT UP
"also noticed the back plenum has those spring loaded clamps that over time loose grip.you may want to remove and put ring clamps on there as well"
ZIPPED IT FOR NOW, WILL CLAMP LATER
"check to see if the plenum has a hole for the egr hose to go into it,this will help rule out a few thing's."
NO HOLE
"aha, also check the big rubber hose from throttle body to air box area."
ALL GOOD
"also noticed the tempstat housing has a leak going on."
PULLED THE THERMO, WILL RE-GASKET
"also your maf isn't sitting properly, its twisted like 15% to much, maf's dont like not being in the exact position."
RE-POSITIONED
RESULT-
NO CHANGE IN CONDITION
D
devilly
Guest
could try cleaning the iac,ldle air control. did you change spark plugs and lead's ? what does it sound like any thing different ?
dirty hands
ipswich qld
magna
no better after the long list of changes what the ?
.. i suggest a compression test ..
D
devilly
Guest
could be a header is cracked,or a rubber line has come off near the brake booster then go towards the back of motor and check there,could also be a cracked spark plug.
that's why i'm asking as your loosing power is there any weird noises going on ? or sounding like timing is out.
have you check for fault codes, via bridging pins 5 &6 ?
Rigga
Gold Coast
VT Wagon
There is a weird "pffft pffft pffft" noise when the car is under load and losing power, it goes away when I take my foot off the throttle.
It's only giving fault code 29, and that's only because the egr is not there.
Immortality
Staff member
Sth Auck, NZ
lout
60
Langwarrin Victoria
still sounds like blocked cat
is this a constant fault or does it come and go
try disconnecting battery for 30 minutes. this will reset your fuel trims to base level
Rigga
Gold Coast
VT Wagon
Can anyone tell me if a stock v6 3.8l 03 series 1 VY cat can be used on vt, or maybe a vs (because there's no egr) system. I'm still scrapping my old ride.
st3r3otyp3
Donating Member
VX HSV VX SS
The cats type wont be affected by the presence of the EGR, the VY may fit, if the bends joins etc are the same get under yours and have a look.
st3r3otyp3
Donating Member
VX HSV VX SS
For absolute simplicity get under the car and unbolt the cat and start the car straight out the extractors bet you it revs better, then you know 100% the cat is ####ed, not to mention you can just visually inspect the cat to see if its blocked.
