wallyman
Have replaced thermostat, new waterpump, new cap topped her up but still boils on about a 18km trip. Running out of ideas, could it possibly be radiator problems ? If so how would l test for this ? Thanks in advance
YesCould it overheat by not bleeding the system properly
You might be up for a new heater tap as they become very brittle with age and might break while trying to put a new hose clamp on. Luckily they are very cheap to replace.Okay so l think l have it sorted, l noticed a small leak out of one of the radiator hoses hidden down below the brake hydraulic system. This has slowly drained the radiator and both my attempts to fully prime the system has failed. I noticed the temp guage spike up then down assuming this was the airlock. I ended up using a big funnel to top the system up for head pressure and used Trevors idea of the container over the bleeder.
Looks like lm up for a new hose or just a clamp where its leaking from, but not an easy spot to get into .
Thanks all replies guys much appreciated
