vt right hand indicator clicking fast and flashing fast
YILDI2
www.myspace.com
FG XR6 TURBO /RIP VT II LS1 Clubby, VR Commodore S
hi guys i just purchased a vt series 2 clubby last nite, so im new to the vt section
the right indicator flashes faster then left
on the rear front and side of the right of the car flashes fast,
do i just need new globes, or fuse ?
if anyone could help me out, i searched but all i got was clicky indicator stalks
thanks
Jarrad
Sherminator
Wollongong
Silver Ex Cop VX Wagon
Yep blown globe, check them and replace the blown one and all should be sweet!
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
If all the indicator globes are working then look to see if one is duller than the one on the other side at the same position. If someone has put a globe in that has a lower wattage than the original then that side will flash faster.
graham7773
VT Acclaim Wagon
While you are checking the globes, look in the fitting for corrosion. Bad earthing can cause this problem.
Rhin0o8
VZ Calais Impounded?
+1 . check the bayonet for cracking or splitting
The globe wont sit right and will earth out
VT's are bad for this especially in the Brake/Tail light wiring looms
vteezr
Defected
30
Renmark
VT Acclaim 3.8 S2
I had to replace almost all of my rear light fittings i kept blowing globes all the time. Took me awhile to realise why :/
a1k3m1
Central Victoria
2003 VY II S-Pack 25th Anniversary
as everyone else has said .. youve got a shonky globe or bad wattage globes, or theres no connection to the globes lol .. could also be a shonky flasher relay aswell. But my first guess would be the globes
YILDI2
www.myspace.com
thanks guys, sorry for the reply, just been flat out with my new job
the indicators were normal again at one stage and now flashing faster on left side
i will have a look for cracks and watts of the globes, thanks alot guys :)
