- Apr 15, 2006
- 22,945
- 21,445
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VT s2 Exec, VX Calais II L67
Yes the VY/VZ had the trailing arm pick up points altered to reduce camber change during suspension travel, coupled with the extra toe arms fitted from VX2 onward gives a more stable rear end geometry.
Camber change isn't a huge issue unless you are drag racing and it squats hard reducing tyre patch contact and therefore traction, for a road car under hard cornering load it should actually assist the contact patch, it's the change in toe that is going to make the rear end do funny things.
For VX2 onwards, only use the 2 point camber adjustment bushes. If you want to be really clever you need to get a wheel alignment done as the car is driven and under load (have someone record a hard launch and see how much it squats) then when the car is on the alignment machine put the equivalment weight in the drivers seat to match the driver and have them use ratchet straps to pull the rear end of the car down and then adjust the rear chamber to achieve the best possible tyre contact patch.
Yes, but the design was improved over the years, modified correctly it isn't the end of the world.
Well with semi-trailing arms, you are basically stuffed. Comes from the Opel Omega. They knew it was a poor-man's IRS and only lowered their "sports" models by 1 cm, but as for the Holden FE2, it is
what 1 inch?
