Calaber
Nil Bastardo Carborundum
- Nov 29, 2007
- 4,334
- 1,357
- 113
- Location
- Lower Hunter Region NSW
- CG Captiva 5 Series 2
Lazza
You will need to access the BCM to see what level is fitted to your car.
The BCM is a gray (might be black on VT - I don't know) box located above the accelerator pedal. Its held in by two clips on top and a plastic scrivet which is best removed with a sharp chisel because it's at a difficult angle to remove properly.
Drop the BCM but don't disconnect any wiring. On it will be a label with the part numbers and other info, and a word indicating the level of BCM it is.
LO - Won't be on your car - it's basically for utes
MID - Probably what you'll have
LUX - Maybe
HI - Nup - Calais only.
If it's Mid or Lux, it will accommodate power windows.
LUX - Maybe
