VU SS Belt Squeal ??
JamesVUSS
VU SS S1
Hi would any one here now whats goin on with my car lol i got a VU SS Series 1. i snaped a power steering belt a few weeks ago and got a new one put on but about 2 weeks later the belf started squealing on start up in the mornings and would go away after about 5 to 10 min. Took the belt back and told them what was goin on they said it was faulty so they gave me a new one, the noise was gone but 2 weeks later its BACK again lol it only does it when its cold. It would be very unlikly to be anther faulty belt wouldnt it could it be a pully but that still doesnt explain why when a new belt is on its gone then after 2 weeks its back, and just so u know the belt is not sliping
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The squeal means it is slipping. New belts will generally need tightening again after a couple of weeks. The other explanation is that your pump is on its way out.
JamesVUSS
VU SS S1
How can u tightin the belt in these things isnt it like auto tighting
NVE_069
Wh Statesman LS1
yeh mine does this at high RPM
black as
I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
Do you think the squeal may be coming from your idler pulleys, its a very common problem
JamesVUSS
VU SS S1
it might but it would do it all the time wouldnt it and plus i took the belt off and they seems to b spinning normal but the car was stone cold
black as
The grease inside the bearing softens up when the car is running and the squeal goes away, sooner or later it will f^&* the bearing.
Put some talcum powder on the belt if the noise comes back I would say its your idler pulleys :thumbsup:
JamesVUSS
VU SS S1
i just strated it this mornin and it not as bad just sounds like a ticking noise sum where on the belt
black as
A brand new belt should make any noise unless the belts faulty
JamesVUSS
VU SS S1
i just took the belf off again this mornin and all the pullys had a build up of grease on the side where the belt sits i cleaned all the grease off from there and put the belt back on n the noise was gone hmm whats a good quilty belt to get should a get a genuine one or ?? and what is good too clean the pullys with i heard that dereaser can *** the belt upp ??
