Bay 13
- Jul 11, 2020
- 237
- 114
- 43
- Age
- 28
- Location
- Dandy
- VT.
Instead of throwing unnecessary money at it go to a brake specialist, Master cylinder would give you a engine light.
A problem with the brake master cylinder will cause the brake pedal to behave abnormally. All the pressure in the braking system is generated from the master cylinder. If it malfunctions, the cylinder will not distribute pressure properly, and the pedal will be affected.
When you continue using your car with a bad cylinder, it will wear out and start leaking. The pedal will also feel spongy, mushy, and may sink far down when pressed as you described.
I'ts your life and others you put at risk so do it right!!
