@Ginger Beer Do you have a build thread on this forum or elsewhere? I'm keen to read about your sufferings /lol
OK, so the mechanic has ordered in a couple brackets that will drop the engine mounts down 10mm. I'm assuming that I'll run into the same tailshaft issue's as dropping the frame?
Also putting in Tuff mounts to eliminate engine twist.
@vc commodore I haven't seen the back of these vents but are they modifiable to open them up?
No build in here sorry mate, just alot of random posts in the "what did you do to your car today" thread
I have a build thread in another forum covering the SS, well, I have multiple build threads in the another forum, from multiple cars over the years, the SS thread covers multiple cars currently though, as it also includes my recent daily's, including the MX5, which is the funest daily I've had for years, even with it's only 120 kwatw
In saying that, I haven't posted anything about the SS for ages, as I consider it finished for what I want it for. i.e. a nice comfy reliable cruiser with more than enough power to get me into trouble cruising around
As for my suffering, mostly only from minor issues from me not complying with good engineering principles, like lowering the K-Frame and not thinking about how that effects the angle of the dangle on the centre bearing, or working out that whilst a PD blower makes great power, it also has issues with IAT just running the WTA intercooler that the HTV2300 comes with. That little gem wasn't really looked into enough on my part, and fitting a interchiller was the only real fix for reliable street-ability and back to back runs at the strip running a PD
I should, and do know better, but occasionally I think "let's just see if it works", which typically bites me on the arse
I would talk to a driveline joint about the effects of spacing out the K-Frame or lowering the engine (lower TUFF MOUNT engine mounts caused me clearance issues with my 1 7/8 4:1 headers hitting the K-Frame) in relation to correct tail shaft angles though if you plan on actually running the car hard and fast, like the drags, tail shaft harmonics start to get weird over 120 mph at the strip, you can bandaid it by spacing out the centre bearing, but, it isn't an optimal solution for high tail shaft speed
I used Hardy Spicer in Moorebank for information about it when they rebuilt my tailshaft
There's lots about tail shaft "black magic" and ensuring the correct angles in the googles if you can sieve through the rubbish
The PD LS1 with 500 hp in the SS is currently brilliant though, but, if I was ever to do it again I would probably go turbo for, it would have ended up being a lot cheaper, and another less mucking about
The best, and one of the cheaper mods has been the RaceTCS
https://www.racetcs.com/ , it makes all that PD power from idle usable on 255/40 17 Hankook RS4 street tyres with a 0-100 kph in 3.9 seconds on the street (tested on a "private road")
