VX SS creak and clunk
SS-LS1
VX SS commodore 5.7 m6
Hey all,
I'm new here and need a bit of help. Ive done searches through the site, the web and ls1 forums. no help as yet...lol
My VX has a bit of a clunk/creak in the front end, you can hear it and feel the vibration through the Accelerator pedal and firewall/ floor pan.
Its only at low speeds when taking off and/or cornering
I have replaced the sway bar link pin bushes on both sides, replaced the upper bearing plate and bearings on both sides(above strut) and checked and tightened all the front end bolts i could see. all the bushes "seem" to ok.
i also had pedders take a look at it and they wernt to sure either.
i was told maybe really bad pinging, but my plugs seem to be ok and its running fine
also took a bit of a look at the engine mounts and checked my exhaust for clearance...
I'm out of ideas PLEASE help!
Thank you in advance
I just noticed also if you start the car when its cold with the throttle half depressed it also makes the noise
... guess no one has any ideas?
Oranger
VT SS Commodore 5.7
Well making the noise stationary with foot on the throttle isnt going to be suspension. Are you sure your engine mounts are ok? Is your exhaust cracked by any chance up around the firewall area?
Adam.
