vx supercharged boost
hatziVT
VT executive
hi guys, i was just wondering if you are able to run a 19psi pulley on a vx supercharged l67 engine safely without at risk of blowing something or causing damage?
can anyone help me out! thanks
nemesis_adrasteia
better to reign in hell
longford, victoria
VR commodore HSV(without all the gay ****)
19 PSI intercooled?
what fuel are you using?
i doubt it will handle it for an extended period.
hatziVT
VT executive
well i have 12 psi atm and i have the intercooled 25mm insulator from MACE and i was wondering if the engine will withstand the 19 psi?
hatziVT
VT executive
but i have also port and polished my heads and opened them up with alot of other mods like cam and roller rockers..will this make a difference?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
as long as the intercooler is keeping temps down youll need injectors and a tune to suit
hatziVT
VT executive
MACE say that the 25mm insulator works like a intercooler anyway so and i also have bigger injectors anyway, however if thats the case i wont risk it and stick to the 12psi
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
25mm spacer is nothing like a cooler youll still be pumping extreemly hot air straight down the engine dont fit a higher boost pulley
Fletch_QLD
Brisbane Bayside
VU II SS
So no intercooler? Then no chance of gaining benefit - safely or otherwise, going above 12psi.
