HSV08
- Jan 8, 2012
- 245
- 3
- 18
- Location
- Auckland New Zealand
- VT HSV SENATOR SIGNATURE
So got a vx v6 wagon, the motor run a bigend 2nd day i had it.
brought a second hand VS ecotec to swap in. Changed intake manifolds over and bolted back into car.
We broke the top Selector switch pad plug when trying to get it out but the pins were exposed so we plugged the plug back onto the pins (basically the same except it no longer has an outer casing).
all loom is original vx stuff.
Key on i get reds, pump stays running/priming (doesnt stop while key on), iac is moving out or in, starter wont turn over.
Bridging pins 5 & 6 it doesnt register and wont flash up the CE light ( just stays on like normal on reds)
Dash in diag mode it registers the CTS at -40 which im sure means dead?
Any clues or starters on where to look?
