adventra lx8
- Dec 15, 2013
- 5
- 6
- 3
- Location
- kempsey nsw
- adventra lx8
may be posting this in wrong spot not much of a computer guy but thought i should let people know what ive found (sure most probably already know but if i can save one person some money im happy) So if your cv's on your front prop shaft are buggered or your rear tailshaft for that matter dont pay $400 for diff end and $300 for transfer case end as i was quoted by bursons (he would not sell them to me he thought i was a rip off so he gave me his part numbers and told me search the net so i did) the diff end cv is the same as fg falcon or jeep grand Cherokee (front tranfercase end) 25 spline count 100mm OD non plunging starting from $50 on ebay. transfercase end cv is the same as VB-VL 6cylinder tailshaft cv 24 spline 94mm OD plunging type starting from $50 on ebay hope this saves someone $$. only issue is transfer case cv needs spline ground down a little so circlip will seat and rear dust seal trimed so if your not confident pulling a cv apart maybe give this cv a miss. the job itself is easy pull cv apart grind lip off splined piece so same thickness as original reassemble then trim flange off dust cover as there is no recess for it to press on done. part numbers i have on my cv diff end brand gsp number cvj.cht1 transfercase end unbranded number cv8562011012 hope this helps .
