03batterydrainer
- Dec 24, 2022
- 14
- 13
- 3
- Age
- 21
- Location
- Dalby 4405
- O3 vy Berlina
My 03 Vy Berlina never had any issues with before hand. has been draining the battery every day for the last 2 weeks. I did the usual. Changed the battery 3 different battery's, same thing. changed the alternator. Stuff like that.
I've spent that time researching on here and chased up a few things. Earth wires, fuses. Stuff like that it all seems good.
My back door recently decided it won't lock/unlock by the key. Not sure if that could be the issue.
Sitting there idling after a while it starts to surge sort of thing, revs drop to 500rpm and back up 1000rpm, with the lights etc on and idling my volt gauge goes between 14.2v an 14..3v if I rev it up a bit. It will pick up to around 14.5v. it's seems normal.
I had the dreaded fault codes come up on the dash ABS SRS etc found the BCM fuse had bad contact. as some people had experienced that. Changed that and haven't had any faults so far. But my battery is still draining, I've pulled interior light fuse. My stereo shuts down properly. Everything seems perfectly fine besides my battery draining now still. I don't have access to a scan tool of any sort. I know it could possibly be the BCM failing but I'd like to try and see if it's anything else first before I spend a ridiculous amount on BCM etc
Just chasing a few pointers on what to look at that I haven't already.
