Steve,
This car was a repairable write off, rather than a stat write off, be very carefull and check the car against the register before purchase. A stat write off can never be re-registered I understand in victoria.
Yes it was worth in the long run, but not counting labour time.
I brought all genuine parts from my local holden dealer which made it more expensive than say buying another wreak to fix it.
The next one will not have airbags deployed. Its a very big job inside to change all the dash etc. I would also recommend either being freinds with a panel beater who can access VACC or similar for veichle dimensions when welding up the front.
Also, if hit in the front, inspect the K frame. It is designed to deform, I didn't know this at the time.
If you have any other questions don't hesitate to ask.
Regards
Matt
