VY Ute rear craddle
ONROADYNO
VZ Thunder
I had my ute wheel aligned today and they couldn't get the rear camber/toe correct even with a camber kit installed. My only guess is a previous accident.
Is there anything I should check before spending time and money on another rear cradle?
Thanks in advance.
lowandslow
NSW
V2 III Monaro
How incorrect is it?
And by camber kit, which kit? Is it a 2 or 4 point setup?
ONROADYNO
VZ Thunder
Whats wrong with it?
It's never going to be perfect being IRS.
The suspension tech said he wasn't happy with the out come, sighting possible collision. I am no expert but the way I read the printout, the toe is perfect but camber is out.
I guess my question is it too far out?
Thanks.
ant797
bunbury
vy s
i had a corolla where i changed the cv joints then took it for a wheel alighnment he said the camber was out i told him i changed the cvs he asked if there was any play in where the shocks bolt onto the hub in out play turns out i needed to undo the two bolts push it in then tighten up again nevermind just watched a video doubt the shocks would effect it the way there set up on these
lowandslow
NSW
V2 III Monaro
If it tracks straight and drives fine i'd back the other one off until it matches the other side.
If it's copped a whack you'd expect both camber and toe to be out.
Unless you have coin to spare swapping in a used trailing arm or unknown quality i'd adjust it and live with it.
ONROADYNO
VZ Thunder
Thankyou. You are 100% correct. A used trailing arm or indeed a used cradle may not even fix.
I will be going option A and just see how it goes.
