Dirbatua
AWOL!
- Apr 6, 2003
- 3,910
- 167
- 63
- Age
- 36
- Location
- S/e Victoria
- VX SS Series 2
I will be after VT/VX testers next.. then finally... release. :beer chug:
WOO :rockon:
What would I need to do if I bought a 3window cluster that was already programmed. Can I just bolt it straight in and plug it in. I'd be putting a Calais cluster into a base VY ute
Ahhhh, interesting job!. Im sure as you have seen,there are more pins on a VY cluster then there is on a VX.. so you have to get creative with keeping everything happy. Also note, the communication between a VY and VX is different, as in the messages sent on the comms line differ between VZ and VY which is a reason why some weird and random warnings pop up on the cluster.Hi Tazzi, I'm putting a WK cluster into a series 1 V2 CV8 Monaro (VX). The fuel gauge works fine (yay) but I was wondering about error messages that are coming up.
The SRS errors, do they go through the BCM? If so will the VX BCM put out the wrong signal for the WK cluster thus causing the error?
Also alarm activated errors. Is this from the security warning wire on the WK cluster? The VX doesn't have a wire but if it were simply a matter of the right voltage on that wire I could easily sort that.
Finally, how does the WK dash detect rear lamp and lamp fuse failures, and does that go through the serial data wire or is there another wire?
Thanks heaps.
One tonner's come under a cab chassis :beer chug:Hi tazzi , been meaning to tweak the dash on my one tonner .
What setting do I pick ? , the cab chassis or the ute ?
