imnothereanymore
wizfiz
i have a dash apart on my bench now playing with "things" im keen to test also tazz
Its probably the most delayed, unbelievably delayed, constantly requested software for Holden programming so far!.
It is on its way. Im doing final alterations on the VT,VX clusters section and then it will be up for beta testers which will be advertised the companies sponsor section! :beer chug:
UCC has now bee retired. Due to the reason you have quoted. The application now has VT,VX,VY and VZ cluster programming support which includes re-configuring main parameters such as engine size, transmission, airbag setup, fuel configuration plus a few other bits. It also has the ability to bring up some info about the cluster including serial as well as read out cluster fault codes (Useful for identifying if a module in the car is not communicating!)
Again, there is no expected time for finishing, due to the huge amount of development going on with other projects at the same time such as SOE.
Hi Tassi
Quick Q: I know the PCM and BCM talk a different messaging language hence the PIM, so I wondered do I need a BCM and PIM just to get the cluster to read speed and tach or can I go straight to the engine PCM for those?
Thanks in advance
Sadly enough not the case! Until the last few days Iv had to manually obtain,decode and write programming frames to the clusters as my old software was destroyed by having too much faith with an online database which I kept all my workings on the software *sigh*. Lesson learnt, multiple backups on multiple places online and offline!Im pretty sure they dont want to release the software cause they want to making lot of money
Literally, and I mean literally, just completed the application this afternoon. I will be popping up a thread later tonight with details. Not the same as the above application I displayed. Have compiled SRS,BCM,radio and cluster diagnostics (Including Cluster programming) for VY/VZ into one application.All I want to do is change my damn fuel level gauge so it reads correct.
