The design of the valve is to remove the oil vapours in a measured way. It’s a Venturi valve. No internal parts though.
You don’t want to creat a vacuum leak or problem either.
I've noticed a subtle improvement post mod and would definitely recommend it to anyone who hasn't had it done yet. Not 100% certain if I'm deluding myself or not, but it feels a bit more responsive and less sluggish. All for 15 minutes or so of work.
Oh, I can find way easier ways to create vacuum leaks.. *cough* snapping an intake manifold bolt *cough*
Reminder to not set the torque wrench whilst being distracted by someone/something. You know, I should have jerried when I was turning it and even thinking, gee this going on for a bit...
Luckily a middle bolt and pretty sure there is enough poking out that I can spin it out with vice grips.
On the positive side, the intake manifold and throttle body are cleaner than ever.
One question arose from removing the intake manifold; the inlet closest the firewall on the driver side was pretty foul, the passenger side less so. The middle driver side was foul, the passenger less so. The front most inlet on the driver side was also foul but less than the other two on that side, the passenger side was fairly clean.
From a diagnostic perspective would this be saying anything? It seems the driver side bank is fouled quite a bit more than the passenger side. I've cleaned them all out now, and will review it after a while given I've modified the PCV valve. Interested to see if anything changes.
