I just took mine off and it seems to be nearly new! Which it might’ve been replaced im unsure, I don’t have the right size drill bits but when I get them I’ll take it off again and do it!View attachment 207622 So I did the second one that goes on my VE Calais.
This PCV came from my VZ. (I used a spare on that)
Of note is that the two holes are actually slightly different sizes. A smidge under 1.5mm.
You can see the bits of red thread lock.
(Remove: Visegrips, rag over the PCV, twist back and forth, then pull.)
You can see the mark left on that ridge from the vise grips, so hence why I suggest a bit of rag over it.
You can see the holes are small.
Drill 2mm for the bottom and 3mm for the top.
I did drill 1.5mm for one hole and 2mm for the other, but considering it isn’t written anywhere that the two holes are different sizes (or why) I said “meh” and did the other at 2mm as well, like I did on the first one that went on the VZ.
Top at 3mm.
I used a magnet to clean up swarth and then a good squirt of throttle body cleaner through it. The straw fits down the holes now.
To reinstall, I used a 12mm deep set socket.
Tap it in gently with a small hammer. A short socket extension helps make it easier to tap in.
*It should remain harder (more resistance) to blow through from the top than it is to blow through from the bottom. (Had to be careful how I wrote that)
I tried uploading what came out of it but the file was too big, nothing even came out just cleaner in one end and out the other, only gunk is on each end, still gonna drill holes to prevent it from building upAs long as it’s clean inside
