kinetic5957
- Feb 2, 2024
- 4
- 7
- 3
- Age
- 37
- Location
- Victoria
- Vz clubsport
Hi guys
Recently wanted to upgrade my taillights to LED globes, had issues with getting them to tell the difference between stop and parker function. I found a thread on here about relearn procedure for the bcm.
So I did what they said and removed the bcm fuse under the bonnet to reset the bcm to put it on to learning state.
However after removing and replacing the fuse the car won't start and the key won't lock and unlock the doors. All the dash light comes the fuel pump primes on but the little lock light witch I assume is imoboliser is flashing and no crank. I have tried leaving the key with the ignition on for a while to no avail. Is it possible by removing the fuse it has forgotten the coding of the key or unlinked the bcm,ecm etc?
Any help would be highly appreciated
