andyman
The Only 6sp VZ Wagon
- Mar 29, 2005
- 3,783
- 68
- 48
- Age
- 34
- Location
- Orange, NSW
- 2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
If the car starts there should be no reason a mechanic etc cant get into the computer. I've been tuning a while and I also have just a scan diag device.......... which reports errors........... the only thing I could think of if nobody can get in is if the BCM possibly isn't updating the security code as it changes.
You should definitely be able to get in, if u cant something big is playing up (by big I mean a main device, BCM, TCM, ECU)
Suggestions I have which probably wont help:
1. Try a relink of the vats system (relinks the bcm to everything for the immobiliser side of things).
2. Powerchain errors generally are some kind of fault, no doubt a sensor one or more in your case.
3. Transmission fault obviously lies within the transmission being in safety mode therefore limiting how fast u can drive it.
Need to know more, water damage? as in flood......... how far under water........ error codes, I know you cant get in but really........... u need to get in to find out the codes.
My dad and I have been repairing a "repairable writeoff" but it wasn't water damaged, but again......... random faults for you.
What year model lumina, v6 or 8 or......
Another idea, again u need to know faults but you'd have to get a Auto Electrician to check all the sensors and solinoids including the O2 sensors in the exhaust.
PS. As for the door locking thats seriously odd....... Sounds more like a short or something there from maybe some dried up water linking some circuts....... I can guaranetee these are all probably small problems, just finding them is the hard part.
-- A seriously smart idea to try............ goto supercheap get some electrical cleaning spray......... like maybe 4 cans of it....... (unhook ur battery) go around the entire car and unplug/replug everything and spray every single plug etc with that stuff, including all under the steering column, dash, anywhere a sensor is.......... spray your whole TCU under the car just everywhere u can. It may not help at all, but it'll make sure the contacts are all clean & check all ur fuses)
** Sorry for the mass post but the mechanics who couldn't get into the ecu, was this before u had the battery replaced? ......... if so there probably wasn't enough power to power the ecu.....
the PIM (powertrain interface module) will cause no communication to the DLC (Diagnostic Line Connnector) the pim runs the can bus signal around the car and links the various components, the DLC also utilises the pim to work, i will have to look in my book, but im sure it does,
if the pim is dodgy or cooked, you wouldnt be able to sync with the computer, it will also prevent different components 'talking' to each other and cause faults,
