Powertrain errors, very low fuel warnings and wrong coolant readings are the signs of the ecu going out.. Horrible news but seems to be a common issue in VZ's, mates VZ shat its ecu not so long ago, RAC came out to have a look and only way to start was to bypass relay. So got a new one fitted and car has never ran better. Of course.. this isnt eaxctly cheap to do!have you had any power train display come up. i have 06 vz wagon and i have a power train warning come up sometimes has anybody had this prob
hey people, i have an error logged on my dash when my car wont start. it wont start because i get the very low fuel error followed by the fuel gauge error, contact dealer. now, normally i have the trouble codes as follows
Hey guys if you are still having trouble finding out what is the go with those "trouble codes"
I found this in another post.
Trouble Codes 1 indicates the corresponding code is set
31 29 28 27 26 25 24 23 22 21 20 19 18 17 16
15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
So for me, the lower left Trouble "bit" was set.
Which after a search said "No serial data from audio system"
I have an aftermarket HeadUnit, makes sense.
The site I used was, and I hope I can post links:
www.carmodder.com • Search Diagnostic Trouble Codes
it also helps to search with 4 digits, so for me I would search "0015"
