Kudrow
Yes another water leak thread.
I have 100% tracked it down to coming in between the door and the door card on the drivers front side. I have removed the bottom rubber and the drain holes are clear AND water also drains out the holes where the yellow clips hold the rubber in. If I run a hose on the outside window and indirectly direct the water down the front of the door (e.g simulating the same sort of pressure as decent rain or auto carwash spray), it runs out the drain holes and the clip holes AND between the door and the door card and this is where it then spills over into the cabin and onto the carpet.
My question is, before I pull the door card off, what is it typically given the above? Is it the top external seal that causes this on the outside? I mean the top seal would not keep out all water in a torrential rainfall or carwash but I've read it is supposed to direct water down the door in a certain way? Last I checked, the inner plastic seal and sticky black butyl rubber was still very much intact.
Cheers.
Cheers.
