Keegzzz
- Jun 19, 2013
- 153
- 1
- 16
- Age
- 29
- Location
- Carlingford
- Vt Calais
So my car is in a crisis at the moment, first the strut hats are worn, then needed engine mounts to be replaced, then had a pressure test which resulted in heater fore leak and now I believe the water pump is leaking. Noticed a fresh coolant stain directly under pump and upon further inspection saw a leak just below and to the left of pump on the engine block. Is it a matter of just a gasket replacement or should I go ahead and replace pump to?
I doubt I'll be keeping the car much longer as it's proving to be quite the burden but for the time being I'd like to keep it running smoothly
