SLIPPERY PIZZA
Hi, I Have Read A Lot On This Site & Others Re The Above Subject.
Questions Arise:-
1/. Has Anybody Done The Figures Before And After Weber.ie. L/100 Kms.???
2/.some Have Just Said Great Runs Better , More Power Etc ,in My Day Of Fj's Eh's Etc More Power Meant More Fuel, Maybe Technology Has Changed??
3/.regarding Dumping The Est. System (it May Have It's Problems,however Not That I Have Had Cause To Complain), Gmh. Claimed It Upped The Power & Most Of The Old Mechanics That Did Their Apprenticeships On These Models Have Said The Same . I Think There Is A Difference With Driving One That Has Been Changed To The Blue Dizzy. Surely With A Bit Of Thought The T.p.s. (throttle Position Switch) (not The Secondary Venturi Switch As Someone Called It) Could Be Mounted On The Weber So That A Part Of The Linkage Turns It On & Off -that's It's Only Function - On /off Sent To The Ecu. The Ecu & Est. System Also Ups The Idle When The Air Con.is Engaged. No One Has Mentoned This Point What Do You Do After The Weber Is On-turn Up The Idle To Compensate For The Times When The A/con Is On Or Fit The A/con Solenoid Setup From A Vh To Stop The Car From Stalling At The Lights When You Hit The A/con???
4/.last Point( Thank God Says Everyone) I Would Love To Know The Correct Jet Sizes Etc. For The Weber Before Fittng A 4.1 (ford)
Carby To A 3.3 (weber Usa. Has A Very Helpful Web Site ,full Jet Kit For 32/36 $49us.) If Anyone Is With Me On This Jet Size Question You Will Notice On The Site One Very Important Question About Where You Intend To Use The Vehicle, Climate Etc Etc -remember When We Imported All The British &the Early Jap,& Ford Cars My Uncle Made A Fortune Changing All The Carby Jets For Our Climate
So My Point Here Is That I Live In Nq. Not Tas. So The Jet Issue Is Important. I Wonder How Many Of Our Young Diy. Mechanics Are Aware Of This.
Any Way I Am Finally Finished -if Anyone Has Done The Figures Post It As I Need Convincing Before Making The Change.
Questions Arise:-
