Were to run wires through firewall - for Temp gauge sensor
SRaven
58
Kalgoorlie
VY 2004 Series II 5.7 Crewman
Installing a SAAS water temp gauge to my VY 2004 Crewman.
Not sure were to run the sensor wire through the fire wall. Would appreciate any advice,
Regards
SRaven
Immortality
Staff member
Sth Auck, NZ
I used a bit of welding rod (with the flux removed), just sharpened the point and then pushed it through the side of the main wiring loom grommet in the firewall.
losh1971
North Tas
VE Series I SS Ute
Does the VY auto have a clutch grommet, like some of the earlier models?
07GTS
Australia
VEGTS BUILT BLOWN E85
there is a small grommet on passenger side under/behind the glove box that isnt used
SRaven
58
Kalgoorlie
Thanks I will check it out
Immortality
Staff member
Sth Auck, NZ
Probably but it comes out in a **** location close to the engine where there is a lot of heat and not ideal for electrical cables and also probably hard to access under the dash. It's not my preferred location.
